88 hurricane bar end help
Old Sep 29, 2012 | 03:28 PM
topgunsc's Avatar
New Member
Default 88 hurricane bar end help
i was replacing the hand grips on both sides and wanted to add some bar ends because the bike didn't have any when i got it. no problem with the grips. on the left side, i tried to screw in the bar end and it wouldn't screw in, so i was able to remove the part inside the left handle bar and install the bar end. the throttle side is giving me an issue. there is a piece inside the throttle end with a thread. i can't get it out to replace and install the new bar end. any thoughts. here is a pic of what it looks like inside the throttle end (http://i984.photobucket.com/albums/a...hrottleend.jpg).
Old Sep 30, 2012 | 06:06 AM
Fobwareagle's Avatar
You'll need a long enough bolt in the proper pitch and thread ( I know its a 6mm thread and i'm guessing a 1.25 pitch ) to screw in to that part and give you something to pull on with pliers or vise grips. Even then it might not be so easy to get out, use some wd-40/spray lube liberally. Good luck
hurricanematt
Aug 9, 2019 12:21 PM
cal_look_zero
Jun 15, 2012 09:34 AM
Saldo1981
Jan 2, 2009 08:43 PM
ebinz88cane
Apr 25, 2008 06:05 PM
BostonCBR600
Mar 15, 2007 10:44 PM
