600rr wouldn't start big time help!!
Old Jan 24, 2007 | 06:24 PM
greenmih's Avatar
Default 600rr wouldn't start big time help!!
Hi everyone! My friend asked me to write here to ask for help 'cos hes is really stuck with his 03 600RR brought from US to Russia. What happened was that he installed a security system on his bike by himself and the bike then stopped starting. Symptoms: no fuel pipe sound, no spark on a spark plug but engine is being spun by a starter. He pulled out the security system and put everything as it used to be, but it still wouldn't start. He said he checked everything, all sensors, fuses and relays seem to work fine. Hes' been running through different service centers here in Moscow for a couple of months with no luck (the level of service here is still very bad). He didn't get the ecu diagnosed 'cos noone has the equipment here to do it, but his friend has put his ecu into his own working rr and it was working perfectly.
Has any1 got any ideas??? Its spring soon and he really wants to get i fixed before every1 else can enjoy riding![/align]
Old Jan 24, 2007 | 08:17 PM
knightslugger's Avatar
Default RE: 600rr wouldn't start big time help!!
BAS tripped?
Old Jan 25, 2007 | 12:56 AM
dcope17's Avatar
Hey, check out my post from the other day in this same section. Titled,
"I can't get my 600rr to start". Read it and see if that sounds like the same thing that could have happened to your friends bike. Simply put though, I had a fuel injector come unplugged because I almost dropped my fuel tank and it pulled on the wiring. The bike came on and the starter worked but the fuel system and spark wouldn't work, Hope this helps.
Old Jan 25, 2007 | 05:17 AM
greenmih's Avatar
He said he checked BAS, but is it likely to cause these exact symptoms? Is that the thing too double-check?
I'll tell him about the unplugged injector, thanks!
Old Jan 25, 2007 | 01:01 PM
sure he checked it, but did he reset it?
hmmmmm........
Old Jan 25, 2007 | 08:13 PM
greenmih's Avatar
As far as I know it's done by switching a killswitch off and back on again?Well, I don't think he did intentionly but during months of testing and trying, i'm pretty sure that he would do it accidently. Or should it be done instantly like on-off-on? I'll tell him anyway, thanks!
Old Jan 26, 2007 | 03:49 PM
Fede RR's Avatar
Between the front lights there's the "flip sensor" ( don't know how you call it in english, it's the sensor that turn off the bike if it flips upside-down) maybe during the transport it has been messed up.....
Old Jan 26, 2007 | 07:01 PM
ORIGINAL: Fede RR
Also called the BAS, or Bank Angle Sensor.
Mojouk
Jul 9, 2013 04:30 PM
suavegav
Jul 5, 2013 05:40 PM
Romparoo
Sep 13, 2012 09:24 AM
210Ryder
Jun 30, 2010 11:13 PM
xander071584
Nov 14, 2008 01:20 PM
