600 rr chain adjustment question
Old Oct 4, 2010 | 09:50 PM
tiger600's Avatar
Default 600 rr chain adjustment question
Bike is an '08 600rr. Owner's manual sez to adjust chain to specified free play with bike parked on side stand. A pain in the A$$. I installed spools on the rear swingarm to accomodate a rear paddock stand. With the bike on the paddock stand, would there be enough compression on the rear suspension to do an accurate chain adjustment? Or would the end result be different once the bike was back on the ground? How do you folks do it?
Old Oct 4, 2010 | 11:25 PM
The bike is still being supported by the suspension when it's on the paddock stand. I've never had any issues that I'm aware of by adjusting it while on the stand as opposed to on the side stand. If there is a difference, it can't be much.
Old Oct 5, 2010 | 03:52 AM
chainstretcher's Avatar
Admin Emeritus & MVN
There will be some difference but not a lot ... having said that you never want it to be to tight. What I always did was adjust the chain to the proper spec on the sidestand and then put it on the swingarm stand and see what the play is. Write it down in the manual and yer golden for the next 100 times
Old Oct 5, 2010 | 07:30 PM
tiger600's Avatar
Thanks guys. I'll try it on the ground and then compare on the stand, just to see what the diff really is. It's just so much easier to do any kind of chain service on the stand, ya know?
Incompatible
Jan 10, 2012 07:32 PM
o2compressor
May 26, 2011 09:16 PM
TheHeggi
Aug 11, 2010 04:58 PM
Perranomous
Apr 19, 2009 03:04 AM
MofoSachem
Oct 20, 2005 03:55 PM
