5Th Gear Neutral
Old Sep 20, 2006 | 06:44 PM
ddvs's Avatar
Default 5Th Gear Neutral
So I'm rolling along, doing decent rpms and speed. Then my 5th grear just goes neutral and to top it off, the neutral indicator light doesn't come on. So I'm sitting there revving the engine thinking it's in gear... immediately I switch down a gear to 4Th then back up to 5th and it works fun. Any ideas about why 5th gear just goes neutral while riding?
Old Sep 20, 2006 | 06:51 PM
Advert25's Avatar
Default RE: 5Th Gear Neutral
sometimes you can hit a "false neutral" inbetween two gears... sounds like its time to get that clutch serviced...
Old Sep 20, 2006 | 07:34 PM
ddvs's Avatar
speaking of the clutch, sometimes it feels like the clutch cable is getting stuck and I feel a little bit of binding/grinding in the level as I pull it. Does that mean the clutch cable needs to be replaced or just oiled? If oiled how much does one of those run?
Old Sep 20, 2006 | 11:13 PM
poorfish's Avatar
You need to adjust the shift linkage down some. It sounds like your shifter is too high up. That's my 2 cents on it .
Old Sep 21, 2006 | 12:11 PM
Reckles33's Avatar
I second lowering your shift linkage, I had the same problem and when I ajusted mine I had no more problem. give it a shot.
Old Sep 21, 2006 | 12:38 PM
rrasco's Avatar
mine did that a few times when i got my bike, but i have not had it happen in the last 6 months. i didnt adjust anything, i did lube replace the clutch cable since it snapped on me. that was fun..(not replacing it, but pushing the bike home)
cnguyen
Mar 20, 2011 06:21 AM
BonsaiSteve
Jul 21, 2010 08:54 AM
predator
Apr 2, 2008 08:53 PM
trafficdodger
Jul 9, 2007 04:33 AM
CBR600F3
Jun 8, 2007 04:04 PM
