Second gear kick in to neutral
Old Jun 7, 2007 | 01:30 PM
CBR600F3's Avatar
Default Second gear kick in to neutral
I have a 97 CBR600 F3. If I in second gear and I get into it, it shifts into neutral by itself. What could be causing this? Thanks!
Old Jun 7, 2007 | 04:49 PM
Northernfirepower's Avatar
Default RE: Second gear kick in to neutral
Does it happen every time? Second gear is tricky like that, if you don't shift thru neurtal into second hard enough you will slip back into neutral most every time. Just be sure that your shifting fully in every gear. I sometimes slip between 3rd to 4th and everytime I do it I wanna kick myself because I didn't shift hard enough. If it does slip everytime, you may be looking for a new tranny.
-NorthernFirepower
Old Jun 7, 2007 | 06:05 PM
Most likely you have a worn shift "Dog". The Dog is a part in the transmission that engages the drive gear with a driven gear. They have pins on their sides that get worn over time, and the rapid accelleration can cause the Dog gear to be kicked out. I may not be explaining it exactly right, but essentially it's a worn part in the transmission that probably needs to be replaced. You wouldn't need an entire new transmission, but some parts
Don't kill the messenger [&:]
Old Jun 8, 2007 | 04:04 PM
CBR600F3's Avatar
Ok what do i need to buy and what wold the $ be
Eric Page
May 26, 2013 10:31 PM
BonsaiSteve
Jul 21, 2010 08:54 AM
photo2u
Jun 4, 2009 01:17 PM
predator
Apr 2, 2008 08:53 PM
ddvs
Sep 21, 2006 12:38 PM
