2001 F4I Idles low and dies
Old Aug 4, 2013 | 06:32 PM
sk8infreek's Avatar
Default 2001 F4I Idles low and dies
My 2001 F4I started idling low but would always stay running. Today I took it out and it died on me, and dies every time I let off the throttle. Any ideas what it could be? Thanks!
Old Aug 5, 2013 | 12:00 AM
froasty's Avatar
check for vacuum leaks, make sure the air filter is clean. check what color the plugs are.
Old Aug 5, 2013 | 11:36 AM
highwaypatrol's Avatar
May be a silly question, but have you tried increasing the idle by turning up the throttle idle screw? If that doesn't work then clean the plugs and as suggested check air cleaner. Also check battery is getting a charge by connecting a multi meter across the battery terminals and rev the engine. You should see an increase in voltage; if not then battery is not getting a charge. You'll have to eliminate things one at a time I'm afraid. Get yourself a Haynes manual for your model. They are a great help.
mgrandon
Aug 19, 2012 09:53 AM
Camelninja
May 28, 2012 09:48 AM
nuttynu
Jul 24, 2010 07:43 AM
mach5
Sep 27, 2009 08:54 PM
afshooter
May 4, 2006 06:39 PM
