2001 929rr pump not priming
Old Jun 15, 2018 | 04:29 PM
delcid777's Avatar
Unhappy 2001 929rr pump not priming
hey guys I’m new to forums but I really need some help. I’ve been looking at the treads but can’t find on that helps me. I replaced the pump. Bad idea. Waste of money. Tested the pump before putting into the bike and it works. Tested the fuel cut off relay and engine stop switch Both work. Bank angle sensor works and engine cut off relay works.. I’m super stuck I’ve been on this for weeks now. Someone please help
Old Jun 16, 2018 | 01:08 AM
CaBaRet's Avatar
Have you checked the 20amp Fi fuse which is outside the Fuse box
Old Jun 16, 2018 | 01:23 AM
74demon's Avatar
Does the pink wire from the ignition switch have 9v?
Old Jun 16, 2018 | 02:25 PM
delcid777's Avatar
I checked all the fuses they are all good and I checked that pink with 2 Greg striped wire from the ignition switch and I am getting 9 volts. I know that if it gets 12 the diode is bad but it’s producing 9. I noticed that the only way I can get the pump to prime is if I pump a jumper cable on the engine cut off relay. But I tested all relays and they are good
Old Jun 16, 2018 | 02:51 PM
delcid777's Avatar
Great news. I was checking the wrong pink wire from the ignition switch. My key broke on my own ignition switch so I got a cheap eBay one . I wasn’t getting any voltage at that pink wire. I added 9 volts to the wire and boom the pump primed! Thank you so much for the help
thegreattree
Sep 26, 2021 07:57 PM
zach929
Feb 6, 2012 07:25 PM
Jim Hou
Nov 22, 2011 07:16 AM
cmarinew929rr
Jul 6, 2009 08:15 PM
Dietrich777
Mar 4, 2009 10:09 PM
