2000 F4 clicking
Old Oct 19, 2008 | 03:58 PM
cbrf4bp's Avatar
Default 2000 F4 clicking
So here's the problem....whenI have to stop or slow down and I pull in the clutch and just coast i can hear this clicking that sounds like it's coming from the lower front. It's a steady click that is pretty much directly related to the speed i'm going (the faster i go the quicker the clicking). It also does it when i coast in neutral with the clutch lever released and in every gear. It will clickuntilI touch the brakes either front or back.I'm not certain what it is, but I do know it's not the chain. I'm thinking maybe the front wheel bearing or possibly something in the transmission? Any help or advice would be great. Thanks
Old Oct 19, 2008 | 09:11 PM
FLYOU's Avatar
Default RE: 2000 F4 clicking
when was the last time the barings were lubed/greased? That's my first guess...
Old Oct 19, 2008 | 09:16 PM
jonld's Avatar
You sure its coming from the front, It sounds to me more like the chain. How often do you lube it?
Old Oct 20, 2008 | 09:14 PM
cbrf4bp's Avatar
I have never lubed/greased the bearings so that's why I was thinking they could be the problem. And as far as the chain goes, that was my first thought and I lube it every time I fill the gas tank (about 180 miles) and check the tension every third tank of gas.
Old Oct 20, 2008 | 09:15 PM
cbrf4bp's Avatar
How often should the bearings be lubed? And just to be sure we're on the same page you are talking about the wheel bearings right?
Old Oct 20, 2008 | 09:24 PM
FLYOU's Avatar
yep. I'm sure you're supposed to do it once a year or something. I know with airplanes we do it once every tire change.
Personally? I'd do it once every 2 years or so.
Old Oct 20, 2008 | 09:48 PM
HAVOC's Avatar
check your chain and rear sprocket. i had a 900rr and the rear sprocket has broken some teeth and it would click sound like you describe . could just be a loose chain too .
Cobretticuz
Jun 16, 2011 07:32 AM
Chrisct713
Sep 21, 2010 02:29 PM
tridge
Apr 18, 2006 03:15 PM
XtremeWeasel
Apr 27, 2005 01:53 AM
