2000 to 2001 929 motor swap HELP!!!
Old Apr 18, 2008 | 02:19 PM
dsc4twenty's Avatar
Default 2000 to 2001 929 motor swap HELP!!!
I did a motor swap from a 2000 929, to a 01 929 motor. It is not running correct. Id idles to like 5 grand by itself. If I accelrate in any gear and clutch in, the rpms stay at where they were when they were in gear, unless i downshift and left out the clutch into a diffrent gear with a diffrent rpm. It runs hot, backfires a litte.. btw, i have full exaust and power commander.. The red light on the dash was on so I took it to a shop and they said got it off.. Sometimes it revs up on its own, and it also makes a weird clunk noise inconsistantly, it almost seems to stall out, but not nessacarrily. I cant count on my local shops and Im thankfull for the net. Please help thanks!
Old Apr 19, 2008 | 04:14 AM
shizz's Avatar
Default RE: 2000 to 2001 929 motor swap HELP!!!
unplug your power commander and see what happens then and also are you having any charging problems my 929 would idle high becouse i had a broken wire from the stator to the rf and the idle came down then i cleaned the wax valve out and checked the cables to the throttle
freestylemotox12
Jun 23, 2013 12:23 PM
moreno24
Feb 20, 2009 01:22 PM
frizzman123
Aug 2, 2008 01:10 AM
jounin_cbr
Mar 24, 2008 05:31 PM
