1st & 2nd shifting
Old Aug 3, 2012 | 12:05 PM
Michaud85's Avatar
Default 1st & 2nd shifting
Lately my bike has been very finicky going from first to second. It just feels like the shift is forced like it wants to bounce out into nuetral, i feel alot more pressure on the top of my foot than the other gears. but 95% of the time it goes into gear. I know that she doesnt like to shift into first unless under 20 mph with some throttle blip either. Is there any similar technique to reduce the amount of strain when i shift from first to second i.e let rpms drop, throttle blip, double clutch etc?
Old Aug 3, 2012 | 12:49 PM
zaqwert6's Avatar
Nov 2011 ROTM
Sounds like you 'may' have a bent shift fork, assuming nothing else seems excessively worn or slipping and you cables adjusted properly.
Old Aug 3, 2012 | 01:14 PM
lewisF4i's Avatar
I've noticed the same thing with my bike recently, every now and then it goes to nuetral and I'm revving the engine going nowhere lol. But it is very 'forced' feeling but shifts smoothly in all other gears. I only have 8k miles could a shift fork be bent with such low miles?
Old Aug 5, 2012 | 01:07 PM
highwaypatrol's Avatar
Sounds as if the clutch may be dragging slightly which would cause your symptoms. Check clutch cable adjustment starting at the clutch end of the cable first and fine tune at the clutch lever on the handlebar. Also a loose drive chain can cause similar problems. Check and adjust if necessary.
Old Aug 6, 2012 | 10:54 AM
Michaud85's Avatar
THanks Highway partol. Ill check that out when I get home today.
rell123456
Aug 6, 2014 01:37 PM
Measuredpath
Jun 25, 2009 03:03 PM
riekky
Jul 15, 2007 07:03 PM
KidCr3nshaw
Oct 18, 2006 07:10 PM
mr tone
Sep 25, 2006 10:10 PM
