1st & 2nd shifting
Lately my bike has been very finicky going from first to second. It just feels like the shift is forced like it wants to bounce out into nuetral, i feel alot more pressure on the top of my foot than the other gears. but 95% of the time it goes into gear. I know that she doesnt like to shift into first unless under 20 mph with some throttle blip either. Is there any similar technique to reduce the amount of strain when i shift from first to second i.e let rpms drop, throttle blip, double clutch etc?
Sounds as if the clutch may be dragging slightly which would cause your symptoms. Check clutch cable adjustment starting at the clutch end of the cable first and fine tune at the clutch lever on the handlebar. Also a loose drive chain can cause similar problems. Check and adjust if necessary.
