16T to 14T Front Sprocket
Old Sep 21, 2013 | 12:32 PM
dance_monkey_dance's Avatar
New Member
Default 16T to 14T Front Sprocket
Hi, Is there any reason I wouldn't be able to swap my front 16 tooth sprocket with a 14 tooth? I'm going for some low end power Thanks.
Old Sep 21, 2013 | 07:39 PM
jeffjones's Avatar
You should be fine to do that.
www.gearingcommander.com
You speedo will be a fair bit off as well
Old Sep 28, 2013 | 03:05 AM
jasonchristopher's Avatar
i just made that swap and loved the bottom end torque i got put out it.
Old Sep 28, 2013 | 08:48 AM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
Dropping down two teeth on the front certainly will do that for you. However, you'll be running at a somewhat higher rpm for the same speed on the road.
Some guys who did a popular -1/+2 gearing change and mainly ride on the street said they did not like the higher rpm and switched back to stock. Your -2 on the front is the same as going -1/+3, an even more extreme change than what they did.
slightreturn
Apr 19, 2013 10:25 PM
aeroworks
Mar 16, 2006 11:57 AM
