12v plug in
Old Sep 11, 2009 | 11:49 PM
frozenpoet's Avatar
Default 12v plug in
I bought a 12v plug in (female part that you plug a car charger into) that is supposed to be able to hook up to the battery. Once I hooked everything up, it had enough power to turn the light on on the car charger, but once I plug the charger into my gps the light fades out and my gps wont turn on. So I played with my wires to make sure they had good contact with the battery and a good ground but nothing helped. Turning the bike on didn't help either, so is there a relay or booster I'm missing?
Old Sep 12, 2009 | 01:21 AM
justasquid's Avatar
Are both wires connected directly to your battery? A friend of mine has his direct to his battery with a switch. Also, a fuse is a good idea to run inline if you havent done so already. he has no problems with his. It sounds like a bad ground connection with yours though.
pipedcbr
Dec 29, 2010 12:25 PM
sean_k
May 12, 2010 05:52 PM
Coopz
May 23, 2008 06:36 PM
Shadow
Apr 9, 2008 02:20 PM
allnath3
Nov 5, 2006 12:31 PM
