1000rr 05 exhaust removal
RE: 1000rr 05 exhaust removal
Im assuming you mean just the slip on. If thats the case. You need to remove your rear tail section. Once you do this, you will seethe bolts that you need to to get to. Also, remove your right rearset. that will allow access to the other bolts you will have to get too afteryou remove the side heatshield.
Once you get there, unhook your exhaust servo's cables from the flapper. You will have to remove the cover and it will expose the cables inside.
Once this is done, there is a clamp that holds on the slip-on onto the the main header/midpipe. Once that is removed, just slip it off.
It took me about an hour to get mine off. Its not as easy as a side slip on, but its not hard, just time consuming.
Oh, and be careful when you remove the tail section. You will need spread it apart to get it over the rear subframe. Its not as fragile as you think and it will flex quite a bit, just dont over do it. Only enough to get it over the subframe. If Im not mistaken, I think I actually had to slide it rearward about and inch as I spread it apart, then it came right off.
