‘03 954 wiring harness question
Old Mar 6, 2019 | 01:50 AM
Rusty43's Avatar
Default ‘03 954 wiring harness question
took off upper cowl today to change speedo/tach unit and discovered a taped off multi-wire connector near the plug for the display unit. Is this a factory checkout plug or am I missing some factory options? I didn’t untape it but I’m guessing it’s got 8 or 10 pins.
Old Mar 6, 2019 | 03:02 AM
CaBaRet's Avatar
Hi Rusty , have a look at this , should be a Grey and a Black connector , I'm assuming your in USA, sometimes Riders "hardwire" them to eliminate connectors
Old Mar 6, 2019 | 03:47 AM
CaBaRet's Avatar
Old Mar 6, 2019 | 09:29 AM
74demon's Avatar
I think you are referring to the junction block for the headlight (and other stuff) grounds. It's a yellow connector wrapped with electrical tape from the factory and has 8 black wires in it. It's located really close to the instrument cluster connector.
It's supposed to be there and taped up.
Old Mar 6, 2019 | 10:01 AM
Rusty43's Avatar
Originally Posted by 74demon
I think you are referring to the junction block for the headlight (and other stuff) grounds. It's a yellow connector with electrical tape from the factory and has 8 black wires in it. It's located really close to the instrument cluster connector.
yes that sounds like it exactly. Thanks
Migge
F2 Tech
May 6, 2014 11:24 AM
mitzu
Apr 3, 2014 07:51 AM
hockeyryan
Oct 28, 2011 04:43 PM
4ws.ba4 F3
Sep 24, 2011 04:55 AM
MadisonD
Aug 2, 2010 06:52 PM
