'02 954 problems
Old Apr 1, 2005 | 06:05 PM
honda_stuntboy's Avatar
Default '02 954 problems
When I turn on the key everything lights up, but my headlight does not and the fuel pump does not kick on. I believe this is also tied to the ignition. Any help would be better than a shop fee. Help Please![sm=dontgetit.gif]
Old Apr 5, 2005 | 01:29 AM
wheeliemonster's Avatar
Default RE: '02 954 problems
Sounds like a fuse. Have you checked all your fuses and relays?
Old Apr 8, 2005 | 11:58 PM
motorbuff929rr's Avatar
more than likely you have a problem with your ignition kill switch next to the throttle, check that first
Old Apr 14, 2005 | 02:07 PM
yellow929er's Avatar
i would check the fuse. had this prob before on another bike. headlight and fuel pump are on the same chain. replaced the fuse to one and they both came back to life.
Old Apr 19, 2005 | 03:02 AM
954doa's Avatar
check fuel pump relay/fuse
Old Apr 23, 2005 | 10:51 PM
Found problem in a yellow jumper near the front of the bike. When I wiggle it the light and ignition turn on. There is not a direct replacement for this, I was told to replace the front part of the wiring harness by the Honda dealer here. $100
m21oliver
Oct 1, 2018 10:52 AM
clintthec
Jul 27, 2011 06:04 PM
honda23
Jun 28, 2011 12:24 PM
cr cbr
Nov 28, 2006 04:36 PM
