Yoshimura RS-3 Install
Old Nov 23, 2010 | 12:21 PM
WiSH2oo0's Avatar
Default Yoshimura RS-3 Install
Hey Guys,
I just picked up a used Yoshimura RS-3 slip-on off eBay. After I bought it I seen it doesn't come w/ a O2 sensor port in the mid pipe. Being that I have a 06 F4i my bike comes w/ a O2 sensor and it had a cadillac converter . I don't have a PCIII or the funds to purchase one and was wondering which route is the best way to go.
1) Install a Dynojet O2 sensor eliminator part #76423005 or do I need a PCIII to use the O2 sensor eliminator?
2) Drill out the mid pipe on my exhaust and weld a 12mm nut to screw the O2 sensor into.
Is there a benefit from doing option 1 over option 2?
Ty
Moses
Old Nov 23, 2010 | 12:27 PM
__Z__'s Avatar
April 2011 Ride of the Month
save yourself the hassle just take it to a exhaust shop and have them weld the bung on for the 02 sensor it will cost like 15-20 bucks...
Old Nov 23, 2010 | 12:29 PM
boredandstroked's Avatar
Weld it
Old Nov 23, 2010 | 12:35 PM
WiSH2oo0's Avatar
whoa, you guys are fast
looks like option 2 it is
Ty guys
Old Nov 24, 2010 | 03:35 PM
Turbulenz's Avatar
Official Welcome Crew
not to step on your nuts... but please dont say "Cadillac converter" ever again..
its "catalytic converter"
I agree with Z.. get a bung welded the right way for a few bucks.. bring your stock mid pipe and have them put it in about the same place to keep the header to O2 length correct... they are probably heated..
Old Nov 24, 2010 | 03:50 PM
wizard's Avatar
Thumbs up
Agree with weld, but you could also bypass it see my later post
Old Nov 25, 2010 | 02:53 AM
wizard's Avatar
Talking DIY O2 (oxygen) sensor eliminator
DIY $.99 DIY O2 (oxygen) sensor eliminator - Plaguarised from the internet
Try a 330ohm resistor
The O2 sensor connection is located behind your right mid fairing
Insert into the bottom pins With the WHITE and Black/White wires
Attached Thumbnails Yoshimura RS-3 Install-closeupconnection.jpg   Yoshimura RS-3 Install-postop.jpg
Old Nov 28, 2010 | 10:05 AM
WiSH2oo0's Avatar
OK, I tried the resistor thing just for ****s and giggles. Once I put the resistor in I turned the key to the On position and my fuel pump didn't prime, so I didn't try and start it. Then I took the resistor out and plugged the O2 sensor back in and now when I turn my key to the On position my fuel pump doesn't prime, so my bike will not start. The only thing I did since the bike ran last was put the resistor into the O2 sensor and I took my front cowl off. Do I need to have my front cowl on for my bike to run?
any help to fix this would be great.
Moses
Old Nov 28, 2010 | 10:44 AM
WiSH2oo0's Avatar
Well I found my answer from this post https://cbrforum.com/forum/f4i-main-forum-11/01-f4i-fuel-pump-not-priming-118984/
NickP123 said, you need your front cowl plugged in for your bike to run. So I ran back out to the garage and plugged it back in and low and behold my fuel pump primed
Moses
