Yoshimura assistance ?
Old Aug 6, 2013 | 07:41 AM
DJPlayer's Avatar
Default Yoshimura assistance ?
I don't I'm going to find any.. I already searched like every forum possible.
I just hooked up Yoshimura EMS. I didn't connect connect to a PC because.. it takes a Serial port!?? (haven't seen one of those since the 90's). Anyways.. so I'm picking up a serial to usb today. Now I already went through the software and maps.. (they're .ems extensions I believe). If you look the notes on the maps given, they're pretty basic. Really really basic. as in CA and a couple Yoshimua exhaust versions. All say stock intake.. and all don't touch timing etc..
Anyone every tried to configure? or maybe even rename a PC3 maps to .ems and open up? Or am I going to have to go to the local dyno and have it tuned?
Old Aug 6, 2013 | 10:49 PM
boredandstroked's Avatar
Well, adding an aftermarket air filter won't affect the curve at all, so thats a non issue. In reality without a dyno session any tuning you do is for nothing unless your running a wide band 02 sensor with constant readout to do the tuning [and even thats limited]
Old Aug 7, 2013 | 09:39 PM
DJPlayer's Avatar
well here's what I did.. I downloaded the PC3 software and maps.. both applications look almost identical to be honest. Both are setup in row/column format that go by rpm's and % throttle. From there I just used the numbers based on my setup and plugged them into the Yoshimura application. Unfortunately not setups utilize any timing advances so it will take a custom tune to be right.
I feel I'm not going to be satisfied until I have it tuned at a dyno. I have 2 dyno's within 10 minutes of me.. One barely uses their's and they said they'll charge like $75 an hour? The other charges I believe $55 for 3 runs.
Do I think any of them know how to tune it properly.. hmm.. I somehow doubt it.
Old Aug 8, 2013 | 07:23 AM
DJPlayer's Avatar
actually I just found 2 more places w/in 10 miles that are dynojet certified tuners. So when they open we'll see how much they cost. I have alot of motorcycle dynos in my area.. I remember when I tuned cars it was virtually impossible to find one (and expensive as hell).
mchl_daly
Mar 24, 2011 01:47 AM
TooBroke0029
Apr 28, 2010 01:04 PM
SchiraF4I
Jun 21, 2008 02:06 PM
KingMushroom
Jun 6, 2007 03:53 PM
EnAhors
Apr 3, 2006 01:06 PM
