will a bank angle sensor from an 06 fit an 01?
Old May 11, 2010 | 08:40 PM
itsgroll's Avatar
Default will a bank angle sensor from an 06 fit an 01?
http://cgi.ebay.com/ebaymotors/2006-...item335ccf6537
will this work with my 2001 f4i?
Old May 11, 2010 | 08:44 PM
vangill's Avatar
July 2010 ROTM
yes, but for your sake get a garuntee its not bad
Old May 11, 2010 | 09:32 PM
RCWhited's Avatar
Yes, but you can always go a cheaper route and disable it...or at least until you get a new one...if you unplug it take a small piece of good wire and stick it in the outer two holes of the connector and tape it up good, it will be disabled and the bike will run without any ill effects until you get one..if you use a short enough piece of wire just the right size it'll look clean...if decide not to get a tipover switch later, you can always cut the connector off and just tie the two outer wires together.
maksim
Dec 7, 2014 12:33 AM
roaddog
Jul 18, 2011 04:28 PM
Phatcbr
Oct 19, 2010 09:37 AM
900rr_Guy
Mar 7, 2007 01:05 PM
elkakandkss
Mar 17, 2006 02:45 PM
