Where can I purchase Brake Hardware
I want to replace my brake pads and rotors. The old bolts that hold the rotor onto the wheel are rusted and I will need replacement bolts. Where can I find the bolts for the brake caliper, brake rotors going into the wheel, and also rotors and brake pads. What DOT fluid should be used? thank you!
Hi there, parts are available here:
https://www.partzilla.com/catalog/ho...nt-wheel-01-06
For rotors and Pads I would probably use ebay, not sure parts suppliers you have over the pond.
DOT 4 for the brake fluid
