Wheel spacing
Old Dec 15, 2013 | 09:46 PM
PossibleOne's Avatar
Welcome Crew Technician
Default Wheel spacing
Allo,
I have an 02. After I got the front wheel off, calipers off, rotors off, I got them all back on and now the spacing seems to be off a bit. its a tad bigger of a gap on the left then on the right. The spacers that go over the hubs are seated inside the hub so Im not sure what the problem is. Everything seems to be in nick and I would like to know if this is normal or it needs to be exact center? The exact gap is like 1/8th inch less ont he right than on the left. Its just when I look at how close the spokes are to the calipers and the rotors to the forks it concerns me a bit. Thoughts?
Old Dec 16, 2013 | 08:23 PM
Scott91370's Avatar
I haven't looked at mine but if the rotors fit in the calipers (and the calipers can only bolt in one way) I would guess that it is right. But, saying that, it doesn't sound like it would be correct.
Old Dec 16, 2013 | 09:06 PM
RudyGT's Avatar
one side has the bigger spacer, the other has the smaller spacer. if i recall right, the clutch lever side has the big spacer
edit: actually i think its the only side with a spacer
Old Dec 17, 2013 | 12:08 AM
yea, its bigger. The one on the left side does come out like the right spacer, its just smaller. Not sure if its called a spacer or not. With that said that makes me think its right. The calipers are on and the front wheel is spinning free.
Thanks.
m4volz
Mar 20, 2008 08:15 PM
BK600
Oct 9, 2007 04:38 PM
lexhart
Feb 15, 2007 12:23 AM
lexhart
Feb 14, 2007 02:33 AM
ianseb76
Mar 1, 2006 11:41 PM
