What is the freaking problem here
Old 10-10-2008, 03:26 PM
ampfp's Avatar
Default RE: What is the freaking problem here
Do you ever hear your fan turn on? It is supposed to come on at say 225/227.
If your fan is shorted, or the wiring to it, then as soon as it tries to come on the wiring will get really hot and the bike ecu and sparks will lose power, draining the battery. Open the fuse to the fan and check the resistance. Also check if the fan is jammed!
Old 10-10-2008, 03:41 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Thermostat, water pump or fan. And whoever it was that had the bike to 250 without shutting down ... damn that must've been a sputtering beast. Mine hates running anywhere in the 200s.
Old 10-10-2008, 04:56 PM
Jaybird180's Avatar
At around 228F I begin to experience low rpm driveability issues too.
Old 10-10-2008, 11:07 PM
nuke79's Avatar
sounds like a failing fuel pump, but the heat issue is what's weird.
Old 10-13-2008, 02:50 AM
projek4's Avatar
okay, I've went out and measured the voltage from the battery.
When the bike if off, the battery puts out 17.3
when the bike if on, the battery puts out 16.8
which I kinda figured something was weird.
What do you think?
Old 10-13-2008, 03:46 AM
That's way too high ... you got a bad regulator/rectifier. Might as well change out the alternator also.
Old 10-13-2008, 10:04 AM
ampfp's Avatar
That could definitely overheat the battery.
Old 10-13-2008, 10:50 AM
Jaybird180's Avatar
Either your measuring equipment is faulty or the battery is faulty.
Old 10-13-2008, 11:49 AM
ampfp's Avatar
I misread this
ORIGINAL: projek4
A battery can't put out that much if it's a 12V. It'll go up to 14 or so, that's it. Did you put a 24V battery in there?
+1 on a bad measuring instrument.
Old 10-13-2008, 04:32 PM
amnesia's Avatar
Not to be nasty or anything, but if you can't figure out what your battery's voltage is, it's very unlikely that you're gonna solve a difficult problem like the one you're having. Odds are you'll just destroy something else in the process. If your bike quits in a corner it could be disasterous. I would get someone who knows what they're doing to look at it.
cbrpaul
07-05-2015 06:05 PM
super60daytona
11-07-2010 11:23 AM
maineiack
01-31-2010 05:41 PM
Gville George
12-26-2008 01:31 PM
Quick Reply: What is the freaking problem here
