What F4 parts will swap tp my F4i ??
Old Nov 19, 2008 | 08:45 PM
throwed_dc's Avatar
Default What F4 parts will swap tp my F4i ??
i did a search and didnt find enough info to make me wanna buy a F4 and see. Basically i wrecked my bike and need some stuff such as side fairings, front rim, rear subframe part with rear fairing, maybe back rim...then cluster n stufff like that but would any of those parts off a F4 fit my F4i..any input will be helpful
Old Nov 20, 2008 | 09:31 AM
xtremef4i's Avatar
Default RE: What F4 parts will swap tp my F4i ??
The side fairings, rims will fit from an F4. However, the speedo/tack cluster and subframe from an F4 will not swap to an F4i without modification. If your F4i doesnt have the split seat like the 01-03 did, then you can use the F4 subframe.
Old Nov 20, 2008 | 11:04 AM
throwed_dc's Avatar
ahh ok thank you
Old Nov 21, 2008 | 04:28 PM
jonld's Avatar
im not sure about the rear rim but the front rim has to have F4i bearings installed as the axle diameter is different between an F4 and F4i. Something to check before you get a wheel that wont bolt up.
Old Dec 3, 2008 | 09:51 PM
throwed_dc's Avatar
what about the forks?
Old Dec 4, 2008 | 11:45 AM
jonld's Avatar
You would have to have the front wheel and axle shaft or just the shaft and by F4 bearings and install in the f4i wheel. The axle shaft diameter is different between the 2, but I'm pretty sure those modifications will make it work.
john87
Feb 19, 2010 02:35 AM
johnnycrash
Jan 26, 2010 02:35 AM
TW
Nov 15, 2008 09:40 PM
inprogresspres
Aug 26, 2007 01:41 PM
stinky93071
Jun 6, 2006 05:17 PM
