what is this?
Old Nov 25, 2011 | 02:17 AM
hockeyryan's Avatar
Default what is this?
what is the thing below the clutch line? and what is supposed to go into it? am i missing anything?
[IMG][/IMG]
[IMG][/IMG]
Old Nov 25, 2011 | 03:22 AM
Mattson's Avatar
[speculation] some sort of a switch that tells the engine's brainbox when the clutch is pressed? Propably overridden [/speculation]
Old Nov 25, 2011 | 07:05 AM
Thunder Struck's Avatar
wires are supposed to attach to 2 prongs inside there that go into the clip on pod assembly
Old Nov 25, 2011 | 08:10 AM
MadHattr059's Avatar
I believe it's where the clutch kill switch is supposed to be. Will your bike turn over,
in gear, without the clutch being pulled? My guess is you have a couple of wires
dangling, that are shorted/spliced together. Those belong to the switch, that you are missing.
Ern
Old Nov 25, 2011 | 03:05 PM
hockeyryan's Avatar
ya I've got those wires and they are dangling. but my bike runs completely fine.. I'm still confused on what it does.
Old Nov 25, 2011 | 03:09 PM
Mattson's Avatar
Originally Posted by MadHattr059
...the clutch kill switch...
Ern
That.
Old Nov 25, 2011 | 08:56 PM
hockeyryan's Avatar
no my bike doesn't turn over in gear. only in neutral
Old Nov 25, 2011 | 09:10 PM
So even with clutch pulled in it won't turn over? You can only start it with it shifted to neutral? If you replace the switch, you'll be able to park in first and just pull the clutch to start it (without the shift to neutral). That's the only advantage you'll gain.
Not a real deal-breaker, one way or the other, on if it's worth the work. Definetly, don't lose any sleep over it. ;-)
Ern
Old Nov 25, 2011 | 09:28 PM
96shox's Avatar
it becomes a problem if you stall at a green light in gear, with cars waiting behind you and you have to tilt up the bike, pop it in nuetral, then start.
Old Nov 26, 2011 | 01:53 AM
HonDashi's Avatar
Exactly. I was riding around when I noticed that I couldn't start my bike anymore with it in first gear and the clutch depressed. I felt that was weird so I went back home and inspected the bike. Turns out one of those wires came loose so I fixed it and voila! The bike fired up in gear with the clutch pressed.
