Water Pump Leaking Bad
Hi All,
This is my first post. I have spent the last month or soreading and getting familiar with the site. I ran intoa problem with my 2001 F4i. The water pump is leaking from the pee hole and I took the bike to the dealer and they comfirmed it. My question is has anybody changed their water pump. According to the dealer you have to drain the oil from the bike before you can change the water pump. I looked at the service manual and it says otherwise. It does not mention anything about changing the oil. Is the dealer trying to get my money or what? and can I do the job myself?
Thanks for all your help in advance.
RE: Water Pump Leaking Bad
you need to drain the oil just a bit...the bike should be leveled and not on the sidestand. the pump shaft sits transects the bottom portion of the case and pretty much is bathed by oil in the pan. if you don't drain out a bit or keep the bike leveled, then oil will literally pour out of the hole that the pump inserst into. it's pretty straight forward procedure, combined with changing the coolant, bleeding for bubbles etc.
