yosh pipe leaking water...
Old Feb 23, 2007 | 07:04 PM
chuckle1316's Avatar
Default yosh pipe leaking water...
hey,
i just put on my yosh pipe and it is leaking water sometimes at the mid and header connection and also where themuffler is connected to the mid pipe. what should i do? i don't want to take off everything and replace the gasket...maybe some silicon? please help.
Old Feb 23, 2007 | 07:26 PM
dragonium25's Avatar
Default RE: yosh pipe leaking water...
Did you get a full system or just a slip-on? You didn't seal it properly
Old Feb 23, 2007 | 08:15 PM
knightslugger's Avatar
water is a naturally occuring byproduct of the combustion process. be thankful it's leaking water instead of it pooling in your can. do you let it idle a lot? you're not starting it in the winter are you?
Old Feb 26, 2007 | 06:46 PM
ya, i just got it and started it and let it idle...it doesn't leak alot by the mid and header connection though.
hondaguy88
Jul 17, 2011 09:33 AM
Frank Lee
Feb 6, 2011 08:58 PM
Anakedman
May 5, 2008 07:30 PM
Aziz
May 29, 2007 03:02 PM
