Vibration in handlebars |Maintainance
Old Aug 12, 2012 | 08:15 AM
ninja-turtle's Avatar
New Member
Default Vibration in handlebars |Maintainance
Issue: Picked up an 02 f4i 17k miles with extremely soft brake lever, squeeks while riding, handle bar vibrates on braking and loses brake pressure.
Diagnosis: First bled the brakes, deff made a great difference, but I noticed that the pedal would keep losing pressuring and I would have to keep pumping the lever to build it back up.
master cylinder leak? rotors warped? uneven wear on brakepads?
Work Done: Replaced brake pads and rotors. Noticed the brake pads had a great amount of life but had uneven wear which was more then likely caused by the warped rotor. Keep in mind it may be very hard to notice the rotor is warped but research the symptoms
Torqued all bolts to factory spec.
-Axle
-Fork pinch bolt
-Rotor bolts
-Brake Caliper bolts
Greased any necessary parts associated with the wheel and applied anti-seize to all the bolts.
Conclusion: Problem fixed. No more vibrations, no more squeaking coming from the front end of the bike. Immediate braking on level 1(weakest brake lever level) No more vibration/pulsating while braking.
Also changed my oil with Rotella T6 and the bike seems to really really love it.
Oil: Rotella T6 Blue gallon(Walmart) 1 gal enough
Oil Filter: Mobile M108
*If you have been riding your bike for awhile, go through and at least torque bolts to factory spec because some tend to loosen after awhile.
Old Aug 12, 2012 | 08:35 AM
74demon's Avatar
Why did you put anti seize on your bolts? Some bolts are supposed to have thread lock on then, which does the opposite. Maybe that's why your bolts come loose....
Old Aug 12, 2012 | 09:10 AM
New Member
I didn't put anti-seize on all of them. There were a few with thread lock. The pinch bolts being one of them.
The loose bolts that I was referring to was caused by the previous owners. I just recently picked it up
SPR-GRN
Jun 14, 2011 09:39 AM
tiger600
Jul 21, 2010 10:09 AM
adam833
Jan 19, 2007 11:09 PM
lumberman
Aug 12, 2005 12:42 AM
