Vibration!
I get some annoying vibration once I hit 7000+ RPM. It sucks it makes me not drive in that RPM range. The vibration is annoying and the bike also seems really loud when it's doing it.
I installed a Power commander and loaded a map on there and it was SMOOTH I was loving it!
I tried another map and it wasn't as good, so I switched back to the one that was good but it sucks again.. WTF now I don't know what to do. I so want to get that RPM range back again to how smooth it can be
Any ideas?
Any ideas?
Try sending the "zero map" or "stock map" to your bike. Then replace that with the one you liked. That should do it. I just recently experimented with maps and had to do that to get the gains I was getting before tinkering with it. I wish I knew more on how to change the individual settings and richness but I don't really want to mess with that.
Good luck!
Good luck!
Well I tried using the zero map, then the slipon map (the one that used to be good). Then I tried the stock map, then the slipon map.
No luck!
Did an oil change too and no luck.
This sucks because now that I know how smooth the bikeCAN bei'm spoiled!
It just doesn't make sense..
No luck!
