Undertray / eliminator - pics / suggestions required
Old Sep 24, 2011 | 07:46 PM
  #21
causeman8's Avatar
^^I installed a hugger the same time I put my undertail on and I havnt had any issues with crud getting in my lock. I went with a hugger mainly because I didnt want my undertail getting chipped by rocks and such but I guess it also works for the crud issue as well.
Old Sep 24, 2011 | 07:52 PM
  #22
gotcbr's Avatar
Originally Posted by Incompatible
Slightly off topic question: With the key mechanism on the bottom of the tray and exposed to the crud thrown up by the tire (no rear fender), any problems with stuff getting into the lock mechanism and damaging it?
W/ the CWFE, my key lock is directly above the tire on the underside of the FE panel. I've never had a problem w/ "crud", water, or any other debris hindering operation of the lock.
Originally Posted by sjsharks33
...I'm thinking of getting a rear hugger to see if that helps direct the crud from flying up to my undertail.
Huggers are designed more for keeping debris/water off the shock & rear of engine, not so much as "fenders". That's what your undertail/battery tray is for.
Old Sep 25, 2011 | 12:38 PM
  #23
Incompatible's Avatar
Gotcbr, thanks.
Next question:
In terms of brightness/visibility, any noticeable difference between the oe light and the aftermarket brake lights? Are there brighter bulbs for the oe light? I prefer the look of the oe light but will go with the more visible of the two for safety reasons.
Old Sep 26, 2011 | 09:30 AM
  #24
gint's Avatar
Hotbodies is ok out of the box. With a little work and ingenuity it can look pretty good and have great visibility.
Yin-Yang
Apr 26, 2017 11:03 PM
bikerbrooks
Apr 29, 2008 02:59 PM
bikerbrooks
Apr 12, 2008 11:04 AM
james007torres24
Jan 2, 2007 02:07 AM
Leveltwo
Sep 20, 2006 09:01 PM
