undertail or fender eliminator?
Old Mar 17, 2007 | 06:49 AM
Stoic's Avatar
Default undertail or fender eliminator?
im currently replacing my subframe and rear fairing and was just wondering if i should get an undertail or just a fender elminator. they're both about the same price on ebay and was just wondering if i could get any input or pictures on this....
Old Mar 17, 2007 | 08:54 AM
pochop7's Avatar
Default RE: undertail or fender eliminator?
I was looking at undertail kit the other day also, I was wondering if they make one that you can still take the back seat off with the undertail installed...since the factory fender has they key hole there, I didnt see anything on the undertail that would unlock the seat. Not trying to steal your thread here but wondered how you would be able to open it without running a wire under the seat to pull to release the latch.
Old Mar 17, 2007 | 11:58 AM
Mad's Avatar
Mad
Which undertail are you looking at? Most eliminators I've seen are much cheaper than the undertail.
I have a rumble undertail. It relocates the key lock to the underside just behind the license plate bracket so yes you can still remove the seat. I am sure the others such as hotbodies, etc do the same. Here is a pic:
[IMG]local://upfiles/9503/CEAC9A0B30D94FBFA1B796E2C8A31F5E.jpg[/IMG]
Old Mar 17, 2007 | 12:07 PM
pochop7's Avatar
I like how that undertail looks on your bike. Thanks for the info on the key hole relocation!
Old Mar 17, 2007 | 06:48 PM
slip_'s Avatar
Most undertails have a relocation for the key, I have a Mototeck undertail, and it relocates it right before the license plate bracket.
Old Mar 18, 2007 | 07:00 AM
Stoic's Avatar
so..where do most fender eliminatorsdisplace the key whole??
Old Mar 18, 2007 | 02:57 PM
xtremef4i's Avatar
fender eliminators locate the key hole around the same place as the undertails. I would recommend getting the undertail since it looks a lot cleaner and custom. I used to have a fender eliminater but I am in the process of switching it out with a Targa undertail
Old Mar 18, 2007 | 07:22 PM
devlzluv's Avatar
im using the eliminator right now till hotbodies comes out with there new one then ill get that.
thegame
Feb 10, 2008 12:08 AM
CBR BoyRacer
Mar 3, 2007 10:31 PM
voodoochyl
Oct 5, 2006 04:02 AM
markobenin
Jul 14, 2006 05:09 PM
