Turn Signal Wire & Popped Hoses Help
Old May 18, 2013 | 01:38 PM
MTF4I's Avatar
Registered Users
Default Turn Signal Wire & Popped Hoses Help
I bought a 2003 F4I pretty cheap from the previous owner who had it stolen and dumped while the guy was running from the cops. It needed new fairings, and the PO had taken off the (apparently ugly) stock front turn signals. New fairings came in from Extreme Fairings and I am in the process of putting it all back together. I found this plug that was cut, so I assume this is the turn signal wire. My new signals have two wires (positive and negative) but this plug has three? Where does the third wire go? Are there two positives and one ground?
Also, upon removing the fairing, I noticed that not one, but THREE hoses have popped out of their fitting. I can't see where they go. Any ideas?
I don't take my motorcycle safety class until June 8th so I have some time to get this fixed. I may just have it towed to the nearest bike place to have the hoses fixed. In my Jeep, I'm more prone to put things where I think they should go, but on two wheels it's a different story.
Thanks in advance.
Old May 18, 2013 | 06:54 PM
74demon's Avatar
What do the other ends of the hoses connect to? 2 of them may be your tank vent and filler drain.
The wires are: green = ground, orange = running light, orange/white = turn signal
There is a thread on how to hook 2 wire bulbs to 3 wire inputs somewhere on here. Most just leave the running wire (orange) disconnected and only use the turn wire and ground.
Old May 19, 2013 | 10:18 AM
MTF4I's Avatar
Registered Users
Awesome, thanks for the help!
Old May 19, 2013 | 12:16 PM
Scott91370's Avatar
The hoses just go straight down and point at the ground. There is a little loop near the bottom of the engine case they go into.
nasty f4i
F4i - Wanted
Jul 12, 2012 02:44 PM
KILOWATT
May 13, 2012 09:17 PM
Turbulenz
Dec 27, 2011 03:23 PM
Cun0144
Sep 23, 2008 10:04 AM
cyber00677
Jul 26, 2007 12:39 PM
