Front 3 wire turn signal harness connectors?
on
1 Post
Relatively simple question..
Does this look like the front turn signal connectors that are on our stock turn signals?
They are listed for an F4i but I want to be sure.. but my bike is at a buddy's garage for the winter..
Edit: I know it's going to be tough to be sure since you can't see the plug end... ugh..
Thanks!
Thanks!
Hmm I'm curious too, since mine are all messed up so I've just kind of wired to them to the ones that get power when I do the turn signals but that just keeps them on.. Are the things on the left what regulates the blinking action? For what its worth, the right side looks like what its supposed to be, and the left side plugs into something that looks like that.. But as your edit says, we can't see accurately lol
if your stock front signals were only signals and not running lights, then yes. only one side is orange, i think. the other side is blue, but the connector may be the same though. if it had marker lights, then no. the green wire would have its own connector (ground) and the plug would have two wires of similar color, one signal and the other running.
on
1 Post
yeah Im almost 100% sure that there are two connectors.. one for the running light/signal light and the other plus is a single pole ground.
I am going to wire up some hot bodies flushmounts with diodes in them to make them function as the stockers.. but i would like to make them up with the harness ends so that I can easier swap out the stockers in and out.. who knows.. might need them for inspection time or something...
