trouble starting and idle
Old Oct 4, 2006 | 05:14 PM
///drift///'s Avatar
Default trouble starting and idle
hey guys so when i start my bike when its cold it will start but wont idle it sounds rough then it will die unless i keep the throttle up.. i turned up the idle to 2k but it still wont hold and it will die.. once it dies it really hard to get it to start again.. but once i ride it for a bit and get it to riding temp it will idle fine.. so what the hell is going on ?
Old Oct 5, 2006 | 03:45 AM
howudoin73921's Avatar
Default RE: trouble starting and idle
spark plugs maybe?
Old Oct 5, 2006 | 11:43 AM
Candymanmo06F4I's Avatar
how new or old is your battery. Is it properly charged.
Old Oct 5, 2006 | 12:53 PM
spdrmns's Avatar
did you change anything on the bike.....ANYTHING?
Old Oct 6, 2006 | 12:40 AM
Pugetpower's Avatar
Kinda sounds like the ECT (engine coolant temp) sensor. Tells your FI system to go into fast idle and when to go to reg idle. You can test for this by doing the "self diagnosis" off your engine malfunction light,
you count the blinks (need the manual for this). The ECT sensor will be 7 blinks. Someone here, no dought, will be able to explain the procedure but it will be wordy.
Old Oct 7, 2006 | 09:04 PM
i have a full akrapovic exhaust.. power commander...not real sure whats all been done to the engine i bought it from a race team in cali.. it has ran fine for a few months but all of a sudden it started running ****ty... i changed the oil still didnt help.. i'm going to check the plugs when i have time.. oh and the batt is new..
dgk600f4i
Jan 10, 2013 11:41 AM
Red82
F2 Tech
Sep 5, 2012 12:49 PM
MrGoats
Dec 23, 2009 10:52 AM
Ron
May 10, 2008 06:01 AM
fullmetalf4i
Nov 12, 2007 09:14 AM
