idle and temp trouble
My bike has been acting up the past few months once it gets warmed up it wont hold a steady idle and will stall out. The rpms will bounce back and forth from around 1500 down to 800 then stall. Also the tempature at idle will bounce 20-30 degress at a time and.eventually over heat. I got the code saying bad iat sensor i changed it yesterday and problem is still.there. a buddy of mine said un hook my powercommander and see if it still.does it. Im going to try that has anyone heard of them malfunctioning like this? Or does anyone.else have any idea of what it.could be?
Thanks you in advance.
check for vac hose leaks. check the hose going to the vac sensor left side of air box.are your throttle bodies synced? have they been synced???fuel pressure regulator might have fuel surges.... check connections on the injectors.. check plugs coils and connections... reset the factory ecu not the cammander....
just thoughts of things to check someone with higher knowledge will come along but thought give ya some ideas to look at
