tire size
Old Sep 15, 2006 | 02:43 PM
rondelf4i's Avatar
Default tire size
Hey i was wondering if any one knew what the biggest back tire was that i could put on my 02 F4I.... and if i put a bigger tire on should i drop teeth on the sprocket??
Old Sep 15, 2006 | 04:47 PM
JVracer04's Avatar
Default RE: tire size
stick with the 180/55
go any bigger and ur gonna loose it in a turn
Old Sep 15, 2006 | 04:53 PM
Blackdog F4i's Avatar
Why in gods name would you want a larger back tire?
It will give you absolutely no performance gain in straight line acceleration. It will hurt your cornering. It will add rotating mass to the bike which will slightly hurt your braking and acceleration.
Stick with the stock size. It's what the bike was designed for.
Seeing a sportbike with a massive back tire means it's either a show only bike or owned by a moron.
Old Sep 15, 2006 | 05:36 PM
lifties's Avatar
Putting a larger tire on the rear wheel, that isn't designed for it, will change the characteristics of the tire. You would think that putting a 190 on an F4i would increase surface contact, but since the F4i isn't designed for a 190, you have to squeeze a the wider tire on to a smaller rim than it was designed for. Doing this forces the tire to become more pyramidish shaped (or triangled shaped), hence reducing surface contact. This is in addition to negatively changing how the tire handles.
And I know this because.... I did it. I was checking out another bike with the same sized tire, and I noticed that even though we had the same sized tire, his was wider. The reason was his wheel was wider and properly designed for that size tire. I did some research into this and found out, I'm an idiot.
If for some reason you still want a wider tire, you need to change out your rear wheel also.
Old Sep 16, 2006 | 04:00 PM
DThompson's Avatar
Yea, stick with the stock application for the tire size. Bigger isnt always better. In this case it is worse.
Old Sep 17, 2006 | 12:59 AM
cbr_racin123's Avatar
As for your question a 200 is the largest before you will hit your chain.
Old Sep 17, 2006 | 12:11 PM
PitbullF4i's Avatar
lol..... well said guys.
Old Sep 17, 2006 | 04:46 PM
ORIGINAL: cbr_racin123
I don't want to know how you know that.[:@]
Old Sep 17, 2006 | 04:51 PM
ORIGINAL: Blackdog F4i
OK
paco383
Jun 13, 2008 10:53 AM
paco383
Jun 12, 2008 08:19 PM
LIM118469
Jun 9, 2008 11:29 AM
Just4Fun
Apr 4, 2008 12:20 AM
DWT74
Jul 10, 2007 08:22 PM
