Tips for Tank Pad
Old May 7, 2007 | 01:40 PM
camaro68's Avatar
Default Tips for Tank Pad
Are there any tricks to putting on a tank pad other than just cleaining the areasticking it on there? Should I heat up the adhesive first?
Old May 7, 2007 | 02:06 PM
Ruftags's Avatar
Default RE: Tips for Tank Pad
Both times I only used alchohol to clean area then put it on. They both went on simple. However taken them off is different. I took the first one off and a couple flakes of paint came with it. Usin a hair dryer to warm glue probably would have avoided that.
Old May 7, 2007 | 02:26 PM
Tahoe SC's Avatar
stick it upside down from maximum coverage...seriously.
Old May 7, 2007 | 05:24 PM
K0NPHL1C7's Avatar
I just got a Harris CBR tank pad protector, before I had nothing and my black leather stained an area of my tank. It cleaned right off but it was a good indication as to what area needed to be covered. The Harris sticky seemed to provided adaquate coverage.
Anyway, after stiking mine on there I noticed in just a couple spots it didn't stick 100% on the edge. I hope it doesn't get worse...
Old May 7, 2007 | 08:08 PM
camaro68's Avatar
Cleaned the area w/ a little alcohol then put it on. Went right on and seems to be on there solidly.[sm=wootwoot.gif]
Old May 7, 2007 | 09:05 PM
jaynd's Avatar
like everyone else has already stated.....clean the area w/ soap and water, then take a hair dryer and heat up the tank pad you plan to apply to the tank. get it warm enough to soften the glue and make the tank pad limp. then, line it up how you want it and smack'er on!
dsenk48
How-To: Mechanical
Sep 22, 2013 08:09 AM
SACBR
Jun 19, 2011 11:09 PM
Jesse2008
Sep 11, 2008 10:26 AM
RooR Mast3r904
Apr 13, 2008 08:40 PM
