Throttle cable issues
Old Sep 8, 2016 | 03:43 AM
paulbin's Avatar
Default Throttle cable issues
I've just fitted new aftermarket throttle cables to my 2002 f4i but the inner cable is very tight and I have no free play. The adjusters near the grip and near the throttle bodies are both all the way in but I still don't have any free play. My clip ons, grips and throttle tubes are all standard. Any idea what the problem might be. The original OEM cables were alittle better but still no free play.
Old Sep 8, 2016 | 03:30 PM
coalminer frank's Avatar
Is it so short that its causing the engine to rev? Is it so short that its causing the engine to rev when turning the handle bars back and forth all the way each way?
Old Sep 8, 2016 | 06:02 PM
paulbin's Avatar
Its so short that it won't fit in the clip on the engine side
Old Sep 8, 2016 | 07:27 PM
Must be the wrong cable. Take it off and compare it to the one you took off. Get a used on from ebay.
Old Sep 9, 2016 | 09:18 AM
paulbin's Avatar
The originals have the correct part number printed on them so I'm guessing it's correct
Old Sep 12, 2016 | 04:32 AM
paulbin's Avatar
I solved the cable issue. I had to use my dremel and cut about 3 cm of outer cable away. How it works perfectly and I have enough free play
cbr6rider
Apr 20, 2011 08:57 AM
jbrooksF2SuperSport
Mar 28, 2006 04:22 PM
FLYNBYU
Nov 6, 2005 03:06 AM
ampakes
Sep 14, 2005 01:33 PM
Ntense
Apr 28, 2005 03:31 PM
