For those who've asked...GSXR MC on F4i
Old 01-03-2008, 11:09 AM
Tahoe SC's Avatar
Default For those who've asked...GSXR MC on F4i
ok,
finally got a couple of decent pix. MC is off an 03 GSXR 750 and is a direct bolt on. i have aftermarket clip ons in the pix but i also had the MC with stock clip ons and it cleared the fairing stay, etc.
[IMG]local://upfiles/2436/10335861201740FBBACBB61C895B1BCF.jpg[/IMG]
Old 01-03-2008, 11:12 AM
Tahoe SC's Avatar
Default RE: For those who've asked...GSXR MC on F4i
close up...
[IMG]local://upfiles/2436/DA1ECB03B9904E51A2A8F96C81CA3A88.jpg[/IMG]
Old 01-03-2008, 01:10 PM
woodyracing's Avatar
Good stuff tahoe
For anyone doing this, keep in mind the 06/07 GSX-Rs have terrible M/Cs that fade pretty bad and have to be rebuilt a lot
Old 01-03-2008, 02:05 PM
Maybe this is a dumb question but why do people put those bands around the brake fluid reservoirs? I've always wondered...
Old 01-03-2008, 02:38 PM
Tahoe SC's Avatar
there are many reasons...pressure, leaks, UV, etc.
but mine isn't just a band...mine is specifically designed for tennis...not motorcycles (which cost 6x more).
i put mines on there for style points though.
looks > functionality
Old 01-03-2008, 03:37 PM
What made you go with an 03 gsxr750 one?
Old 01-03-2008, 04:04 PM
Tahoe SC's Avatar
it's just what was available on ebay at the time and i knew would fit with minimal to no modifications at all.
it ended up fitting great. just had to find a way to mount the remote resevoir.
if you have the bling, hit up brembo!
Old 01-03-2008, 05:07 PM
any master will work as long as the bore isn't to small for two calipers.or vise versa
06-07 gsxr master work great.i've run them for my handbrake
and recently swap my 954 for the radial.if you use rbf600 fluid/stainless lines and BLEED properly, the brake will be dead nuts......i roll 600ft stoppies with that master
Old 01-04-2008, 02:56 PM
krash's Avatar
I dont understand? why did you do that?
Old 01-04-2008, 03:03 PM
Tahoe SC's Avatar
cause stock F4i resevoir kept stripping to hell and i wanted to see if there was any improvement with radial type.
'feel' is improved, not sure about stoppage.
Quick Reply: For those who've asked...GSXR MC on F4i
