Temperature
Old Apr 21, 2008 | 08:56 PM
SeattleSy#1255's Avatar
Default Temperature
05 f4i: curious what the cruising temperature should be in general. At higher speeds or should I say at constant movement it is lower. Lower speeds, say if I was to cruise slow or be stuck in traffic (stop and go) it rises. I want to make sure it is running at a normal temperature at lower/stop and go speeds. 200+ is what it can get to with fan kicking in.
Old Apr 21, 2008 | 09:12 PM
honda502's Avatar
Default RE: Temperature
Normal, read previous threads. (like some even today)
180-200 while moving, 200-225 in traffic. Above 225 and no fan = problem with switch or fan. Above 225 with fan and temp won't go down at all = stuck thermostat, low coolant, or blown head gasket.
Old Apr 21, 2008 | 10:57 PM
Stephens's Avatar
The F4i is designed to run hotter. In town 200+, highway 178.
07bluesilver600
May 23, 2007 07:10 PM
CBR1987Yellow
Apr 18, 2007 01:59 AM
ChanCBR
Mar 29, 2007 04:10 PM
jeh2324
Feb 27, 2007 01:33 AM
gunrman13
Jan 27, 2005 08:59 AM
