tank grip
Old Aug 7, 2006 | 04:49 AM
stargtsi's Avatar
Default tank grip
im looking for an alternative for the "grip tape" on side tank for better grip....Ive seen stomp grip and Tech Spec's version any ideas for a clean clear look?
Old Aug 7, 2006 | 05:35 AM
dwhite645's Avatar
Default RE: tank grip
I use a clear non adhesive vinyl stuff that's static cling. You cut it to shape out of a sheet, spray on water then squgee it so there's no bubbles. It's more for a paint guard, but it's also pretty grippy and does not peel. I got it from chaparral.
Old Aug 7, 2006 | 08:09 AM
shraz's Avatar
i use tech spec clear one
its pretty good and helps me grip the tank when braking
but the grip coat is starting to peel off. They do give 3 replacement for each side and a tank protector
Old Aug 7, 2006 | 07:00 PM
Blackdog F4i's Avatar
I have heard good things about "Stompgrip" it's clear rubber stuff and it's not supposed to tear up your leathers like grip tape.
05f4ii
Jan 14, 2014 11:56 PM
Mr Pipa
Aug 30, 2011 02:03 PM
schroncc
Feb 5, 2010 10:36 AM
akaseman121
Jun 29, 2009 09:48 PM
