Swapping to a 929 front end??
Old Mar 24, 2005 | 04:49 PM
MondoF4i's Avatar
Default Swapping to a 929 front end??
I was wondering if anyone has any info on this? I have been thinking about doing it for a couple of obvious reasons, inverted forks and bigger brakes. I have heard its pretty much a direct swap but I was wonder how much of my stock front end can I still use and what parts from the 929 I would need. Clip ons? Brakes? Brackets? Fender? ect. Any help is appreciated.
thanks,
Mondo
Old Nov 9, 2005 | 01:43 AM
energycontacts's Avatar
Default RE: Swapping to a 929 front end??
hello, i was wondering if you have performed this yet? if so, was it successful? any problems associated with this, was ride affected? thanks.
Old Nov 10, 2005 | 02:18 AM
ekathryn86's Avatar
I was informed today that the 929 front forks are compatible on the f4 and f4i with no problem. Thinking about getting me some. Also, I was told it handles like a dream with those inverted forks on there. Ebay it.
Old Nov 12, 2005 | 10:12 PM
Homebrew's Avatar
The only F4i parts that will work on the 929 front end are the calipers and hoses.
The 929 forks are much larger diameter, so the triple clamps and clip-ons
won't work. However the controls will slide right on.
There are some clearance issues with the 929 clip-ons and the F4i tank, that
is if you bring the forks all the way over to the stops.
I am going to use an aftermarket upper triple clamp with risers so that
I can use a Renthal handlebar instead of clip-ons, so the clearance won't
be an issue.
You might be able to change the bearings on your F4i wheel to a size
that will take the larger 929 axle, but I'm not sure.
I have heard that the front wheels are the same as far as the rotor
mounting hole spacing and the outside bearing diameter, but I can't
confirm it yet.
It's a cool mod for sure, especially if you do the 600RR swingarm conversion
and use a '01 - '03 subframe/seat/cowl, if you don't already have it.
Makes the bike look more current.
Good luck.
Old Nov 13, 2005 | 01:01 AM
brancart1's Avatar
the angle of the two different forks wont work, the 929 has a different degree.
Old Nov 13, 2005 | 01:15 AM
Homebrew's Avatar
Old Nov 14, 2005 | 12:42 PM
Litre1's Avatar
Anyone know if you can mount a CBR600RR front end? It would be nice to have the radial brake setup as well as the USD forks.
jurgs2007
Aug 15, 2012 06:12 PM
stunt it f1
Oct 11, 2009 09:15 AM
stevefloriojr
Oct 4, 2008 05:37 PM
TrIkKeDoUtF4I
Jun 27, 2007 07:49 PM
Junior
Oct 24, 2006 06:31 PM
