suspension
Old Jul 29, 2008 | 06:43 PM
some guy #2's Avatar
Default suspension
When I brake hard I feel the back end sliding around. Which settings on my suspension should I adjust?
Old Jul 29, 2008 | 07:40 PM
MC_spirited's Avatar
Default RE: suspension
How are you braking? What speed? IF you are only using the rear brake, that is expected. the only time the rear will slide around with braking is by using too much engine braking or too much rear brake. I guess it could get a bit squirrly depending on the pavement quality.
Old Jul 29, 2008 | 07:52 PM
reaper2022's Avatar
I doubt it has much to do with the suspension (but then again, Im not a motorcycle suspension expert by any stretch of the imagination), it probably has more to do with a lighter a** end under braking and too much rear brake. Or if you're downshifting at mid/high rpm without blipping the throttle.
Old Jul 29, 2008 | 08:25 PM
No rear brake at all. All front. I was prolly slowing from 60-70 (no idea really but I had some speed for sure) and setting up for a turn. I recently had made the front and rear stiffer (except the preload). I did not jam on the brakes but it reminded me of my impromptu endo so I backed off after i made the turn.
Old Jul 29, 2008 | 10:04 PM
rolandk's Avatar
Squeeze the tank hard with your knees.
Old Jul 30, 2008 | 03:06 PM
How will that help?
Old Jul 30, 2008 | 04:41 PM
Jaybird180's Avatar
The rear coming up (loosing traction) is a result of too much rebound damping. Unless you're actually endoing, I'd adjust that. How much sag do you have in the rear? Is this happening all the time? Could be your rear tire locking for some strange reason.
Old Jul 30, 2008 | 09:52 PM
Should I adjust front and rear rebound (to a softer setting) or just one of them. I didn't get the rear tire off the ground but I defiantly felt the rear end get light and start to kick out to the right. This was the first time I noticed it but on that same day I felt it do the same thing twice. I can't adjust rear sag (even with stock I should try at least right) and rear preload i cannot adjust since I do not have the tool.
Old Aug 2, 2008 | 10:25 PM
I adjusted the rear rebound back to stock and it seems to have alleviated the problem.
Old Aug 3, 2008 | 10:09 AM
Jaybird180's Avatar
Glad U got it sorted. I couldn't post. :-(
doc6335
Jul 19, 2012 09:05 PM
thatdarkknight
Sep 19, 2006 11:06 PM
PERT1905
Sep 19, 2006 12:14 AM
exup547
Sep 14, 2006 08:10 PM
exup547
Sep 14, 2006 04:40 PM
