Sumthin is Burnin!
Old Jun 1, 2007 | 02:03 AM
01slvrf4i's Avatar
Default Sumthin is Burnin!
so i laid my bike down about 2 weeks ago. (i know great way to start the story) after 2 weeks of it sitting in my garage i finally go out to observe the damage, aside from a cracked left fairing and bent clutch bar all looks well. I turn the bike on and after about 30 deconds black smoke starts comming out of the exhaust and it smells like something is burning, or about to be on fire!I turn the bike off and check all the fluids, everythings perfect. can anyone help?
Old Jun 1, 2007 | 02:35 AM
areacode312's Avatar
Default RE: Sumthin is Burnin!
Are you sure it wasn't BLUE smoke from oil in your cylinders burning off?
This goes away.
Where was the burning "smell" coming from? You should be able to tell what part of the bike it was from.
If the oil level is fine then run the bike again and report.
Old Jun 1, 2007 | 05:11 AM
Stephens's Avatar
Your prob burning any oil that came from laying it down. Let it burn itself out and you should be fine.
Old Jun 1, 2007 | 05:56 AM
01slvrf4i's Avatar
yea it was a blueish smoke, how long should it take for it to burn off? on top of that how long should it smell like something is burning?!
Old Jun 1, 2007 | 10:31 AM
slip_'s Avatar
It shouldn't take that long. The burning smell should go away unless you have another issue.
Old Jun 1, 2007 | 12:19 PM
Don't know if you meant the burning smell was related to the exhaust- but if it smells like burning plastic wiring or if you see smoke from burning plastic wiring then find the source.
If all electricals work correctly and the oil level is fine then run the bike to normal operating temps and see what happens.
WhiteHawk
Jun 3, 2007 05:36 PM
exopforce
Jun 1, 2007 12:47 PM
