Stressing! Do I got a blown head gasket
So today I finally had extra money to change my oil it's been about 4,000 miles since the last time. I change my oil with Honda brand oil and an oem replacement filter. So after I warm my bike for about 2-3 mins I loosen the oil drain bolt and drain the oil. It's been a while so my oils pretty dark. I take off the oil filter and oil comes out and it's also quite dark and not so much milky looking but a slightly dark milky look to it. I just wanna know if I got the early stages of a BHG. I haven't had any overheating problems, no white smoke coming out the exhaust, the overflow coolent tank looks good no discoloration. I don't know if I'm over reacting or what it doesn't look like other pictures I've seen when I searched google but iono help me out.
What a waste of money. Rotella T (blue jug) and a wal-mart filter (for a civic) will give you BETTER protection for LESS money. (bout half as much as the Honda crap).
As for the Head gasket, check the coolant level, if its low its goin somewhere. The cooling system is high pressure and the oil pressure is low, therefore your coolant will not be discolored, but oil will be milky. Since you said it was black (and not yellowish brown), then I wouldn't worry too much about it.
