stock exhaust cut project
Old Apr 28, 2007 | 08:27 PM
mr420420's Avatar
Default stock exhaust cut project
ok i have a welder friend..and i was wondering when i cut my stock exhaust to make shorter and louder...where do i cut and has anyone ever done this?? thankss
Old Apr 28, 2007 | 08:42 PM
#1's Avatar
Default RE: stock exhaust cut project
its alot more work than you think i cut mine at the back by the outlet tube. i shortened it about 6 inches but to pull the guts out is a pain there rivited in but if you have a torch handy its easier i heliarced mine back together but becareful its very thin
Old Apr 29, 2007 | 04:33 AM
2kgixx's Avatar
stock pipe is a bit tricky cause u cant rivet it u have to weld it(f4i and 929 not sure about others). With stock ones u have to cut the side closer to the midpipe, on my f4i i cut the portion that the bracket was welded to and it worked mint, except for the ****ty weldingjob i did.
Old Apr 29, 2007 | 04:39 AM
Stephens's Avatar
I wouldn't suggest it. I will look like crap and sound like crap. Leave it stock until you can afford a real pipe.
Old Apr 29, 2007 | 04:50 AM
2kgixx's Avatar
unless u going to stunt, i wouldnt recommend it either
Old May 1, 2007 | 04:56 PM
mr420420's Avatar
oh yeah, can i see pix of the ppl that did it? thanks
Old May 1, 2007 | 06:00 PM
Dirtytoes's Avatar
i had mine cut for $50...sounds better. and half the weight of that **** is gone...stock pipes are HEAVY!
id give it to someone that has a bike shop and that has done it before....not to just some welder.
Old May 1, 2007 | 09:46 PM
voodoochyl's Avatar
Retired Moderator
ORIGINAL: Dirtytoes
Post up your pics, Stinkyfeet. I curious how that looks...probably the other guys too.
98FRR
Mar 2, 2013 10:38 AM
xxrals22xx
May 1, 2009 02:28 AM
newnut
Mar 4, 2009 01:48 PM
whiteflash
Feb 4, 2009 07:49 PM
