Stator Cover Replacement
Old Oct 26, 2011 | 06:10 AM
HonDashi's Avatar
Unhappy Stator Cover Replacement
Hey all,
My f4i recently got knocked over in the garage, and I found out my stator cover cracked and leaked all the oil.
I have another cover on the way and I plan on using this Alternator (Stator) Cover Replacement - Honda Motorcycles - FireBlades.org DIY to guide my install.
Just wanted to know if there is anything missing from that DIY and if there is any advice I could get from someone who has done this before.
Also, as I was taking my fairings off, one of my vacuum hose (I think that's what it is) fell off. It's the largest one of the three that were protruding from the bottom of the fairings. Does anyone know where that goes?
Thanks
Old Oct 26, 2011 | 08:30 AM
kazspeed's Avatar
Make sure you get oem replacement stator cover....the cheap ebay ones usually have something wrong with them
Old Oct 26, 2011 | 11:58 AM
R Dub's Avatar
October 2011 ROTM
Like Kaz said make sure it is OEM so it fits properly. If it doesn't then you will have leaks. I changed my stator cover and that is a pretty darn good write up. It is really not all that difficult. Flow it and you should be set.
Old Oct 26, 2011 | 03:41 PM
HonDashi's Avatar
I ordered the cover from a Honda dealer here along with the gasket and dowel, so I should be good on that end.
Did you use sealant on the cover before installing? The DIY mentioned some sort of sealant to use.
Old Oct 26, 2011 | 04:01 PM
speedyf4i's Avatar
I just used the gasket on mine and all is well. I think u can throw some sealant where that connector goes through but other than that i wouldnt add any anywhere else.
Old Oct 31, 2011 | 02:35 PM
crazychris1981's Avatar
when i did mine i didnt use a gasket just got some good reusable silicone ( some blue stuff that was recomended from auto parts store) worked great no leaks. Its only been 6 months but no problems yet. The best part about it is you can take off the cover clean off the oil and not have to add any more as long as there is some on there. A guy told me it will even seal with oil on it but i didnt want to find out.
Old Nov 1, 2011 | 02:25 AM
HonDashi's Avatar
Sweet. Thanks for the responses guys.
I'm finally getting my stator cover tomorrow so I'll update after the install.
Update: Everything went really well. Was a lot easier than I thought - especially because a friend came over with a lot of tools.
yog182
May 7, 2009 12:57 PM
Tn929rr
Aug 17, 2007 05:07 PM
VP
Mar 25, 2007 01:15 AM
