Stator Cover Replacement
Old May 6, 2009 | 12:14 PM
yog182's Avatar
Question Stator Cover Replacement
Hey guys i have a general question when changing the stator cover on a motorcycle.. When replacing the seal, what do you recommend to put on it? Should i put gasket sealer on it or let the oil seal it? I have a friend that needs to replace his and before i do it i would like the best option so he doesn't have any more problems.
Old May 6, 2009 | 04:10 PM
pr0jktmayhem's Avatar
i used a high temp sealer i found at kragens. make sure you put enough but not too much. i had to redo mine bcause i didnt put enough and it was leaking.
Old May 6, 2009 | 09:07 PM
yog182's Avatar
That sounds good.. I told him if he stop dropping the bike he wouldn't have this problem but he doesn't listen!
Old May 7, 2009 | 12:57 PM
yog182's Avatar
One last questions. What about the Torque on the bolts for the cover? Are they to be specific or is snug good?
HonDashi
Nov 1, 2011 02:25 AM
Tn929rr
Aug 17, 2007 05:07 PM
VP
Mar 25, 2007 01:15 AM
