Starter turns over but bike will not start
Old Feb 9, 2010 | 06:00 PM
m3ds's Avatar
Originally Posted by jonld
your right and that also eliminates the headlight. I just re-read your post. Why did you change the stator cover? did you get the wires hooked up correctly. I'm thinking your pulse sensor isnt hooked up so therefore the bike doesnt know when to fire.
Hmm I'll check this. We took the cover off because the bike had been laid down and it was completely thrashed, so my friend wetsanded and painted it to look better. When we looked it seemed that all the wires were on there correctly but I will check again! Thanks for the replies guys.
Old Feb 13, 2010 | 07:07 PM
m3ds's Avatar
Okay, the fuel pump isn't priming and we got the tank off and checked the spark plugs and there is no spark. We've checked everything, this is blowing my mind. Help?
Old Feb 13, 2010 | 07:08 PM
m3ds's Avatar
Also which pulse sensor the cam or ignition pulse?
edit: nvm, checked them both and all are connected. I really don't know wtf to do, everything has been checked and rechecked I even downloaded the service manual and went through that trouble shooting all day today with my friend. I even replaced the spark plugs, of course that didn't fix it. Do you think the ECU is bad?
Old Feb 14, 2010 | 12:50 AM
Tyteflows's Avatar
Please keep us posted on this topic. I have no answers for you but would like to learn the steps you are taking and the outcome. Good Luck
Old Feb 14, 2010 | 09:05 AM
skoobydoobie's Avatar
If the fuel pump is not priming, then it could be the BAS, or kickstand switch. To bypass the BAS unplug the connector and put a "jumper" wire in the two outter connectors on the plug. The BAS is located on the rear of the headlight right in the middle, which is why the headlight harness needs to be hooked up. As long as the bike is in neutral (make sure it is) then the k/s switch shouldn't make a difference, just when the stand is up and you put it in gear and it dies then you know that's faulty. You can also "hotwire" the fuel pump to make sure its working. Just hook it up right to the battery, and if it works then it ain't broke (duh)
Old Feb 14, 2010 | 11:30 AM
m3ds's Avatar
I will check that out right now, thanks a lot! I hope this works, I've exhausted everything else we know. And we did hook the jumper up to the fuel pump and it works fine so we know it's not that. I'll keep you guys posted, thanks for the help!
Old Feb 14, 2010 | 12:34 PM
I should clarify that k/s= kick stand not kill switch. sorry for any confusion.
Old Feb 14, 2010 | 03:16 PM
m3ds's Avatar
The BAS relay isn't receiving coil voltage, we jumped the 12v across the blue and black wire and we're still not getting any fire and the fuel pump still isn't coming on. Again, we've tested the fuel pump through the method you described and that is working... so what next? lol
Old Feb 15, 2010 | 08:43 AM
Did you check the fuses? How bout the battery is it fully charged? Does the green neutral light come on? Raise the kick stand, if the neutral safety switch is faulty it will think its in gear and not let it start.Check the kill switch...Not just if its in the right position, but if its allowing the signal to pass when switched to the "run" pos. Also check the clutch switch on the perch. You'll need a multi-meter for that. If you know anyone w/ another F4i then try swappin ECUs.
Old Feb 15, 2010 | 10:05 AM
jonld's Avatar
Do you have access to another f4i? If so try its ignition switch. The ignition switch has a zener diode in it that supplys like 8 volts to the ecu so that if someone tries to bypass it by hotwiring, it gives 12 volts and the ecu will not fire the fuel pump. I've had to fix 2 early f4i's this way. It used to be somewhat common but i havent seen or heard anything about it in awhile.
