Starter location? Bike wont run after
Old 04-09-2013, 10:32 AM
bey0nd's Avatar
Registered Users
Default Starter location? Bike wont run after
20 Amp Fuse Good
Starter relay good
Fuel pump turns on
Ignition good
Kill switch functioning
Neutral switch good
Side stand switch good
battery voltage at 12.4V after many start attempts.
0 Blinks from the dash.
Oil light on... when the bike flipped over it let out a good bit of oil no apparent leak yet...
Wont start ..
WHERE on earth is the starter on this bike can someone take a photo and point to it for me?!
thanks a million to whomever helps.
Old 04-09-2013, 11:09 AM
bey0nd's Avatar
Registered Users
NEVERMIND found the starter... but now i cant see anything but the ground wire off the top of the starter... can you measure the + from the bolt in the front ?
Old 04-13-2013, 04:41 PM
bey0nd's Avatar
Registered Users
The engine was oil hydrolocked... took the spark plugs out and hit the starter and PEWWW!!! oil everywhere... thanks anyways guys.
To anyone else curious the starter is directly above your left hand side case cover and the small prong at the top covered in rubber is the positive side terminal which should read approx. 5.7v when cranking the engine.
Old 04-13-2013, 07:29 PM
dupras2453's Avatar
Wow sounds like you dodged a bullet on that one.
Lawrence Norton
12-24-2013 09:16 PM
Kraztsun
03-25-2011 10:47 AM
cadillac curry
04-07-2010 12:18 PM
Stitches
04-14-2008 04:15 PM
mishab
09-07-2007 01:00 AM
Quick Reply: Starter location? Bike wont run after
