Speedometer stops working while riding
Old Jul 25, 2011 | 11:43 PM
CBR forever's Avatar
Default Speedometer stops working while riding
My speedometer will work when I start my bike and will work for a while. Then while I'm riding it will stop working, but everything else will work like the rpm gauge. I'll pull over and shut my bike off and start it back up and it will work again. What would cause this?
Old Jul 25, 2011 | 11:55 PM
ucyifly's Avatar
Speed sensor maybe? I really don't know for sure, but that would be my guess. Pretty dead here this time of night, so tomorrow you should get some more certain responses.
Old Jul 26, 2011 | 02:35 AM
DonnyBrago's Avatar
Almost certainly the speed sensor, however it is a royal pain in the dick to get to. Does the red FI light glow on your clocks when the speedo is playing up? If it does then read the fault code, chances are it will be code 11 IIRC which indicates faulty speed sensor or wiring. Try unplugging the speedo and cleaning out the connections of any grime and corrosion using contact cleaner.
If (when) that doesn't work follow this HOWTO in order to take out the speed sensor and give it a clean, if that doesn't work then replace it.
Donny's speed sensor HOWTO
Had a very similar problem myself, new speed sensor sorted it.
Old Jul 26, 2011 | 07:10 PM
Yeah the red light comes on when the speedo goes out actually I'm going to try that cleaning out.
Old Jul 10, 2025 | 06:13 AM
Francisco's Avatar
Hi!
So im getting the same problem with the speedo..
over some time with no speed information the fi light comes on and stays on till i restart the bike
That fi code means theres something wrong with the ecu.
but im not shure thers a problem with that.
anny info that you can give about yours?
Old Jul 10, 2025 | 10:32 AM
Scott91370's Avatar
Originally Posted by Francisco
Hi!
any info that you can give about yours?
Don't hold your breath. The posters above haven't been seen in 5-10 years - literally.
Jaybyrd
Jul 9, 2010 10:24 AM
dylan
Mar 6, 2010 06:47 PM
Kuroshio
Sep 8, 2009 08:42 AM
SlavDog
Aug 29, 2009 06:47 PM
98CBR600F3
Feb 12, 2007 12:19 AM
